Sensa Clip not powering on
My Sensa Clip (2 years old) is detected by my computer and is charging normally but when I unplug it from the usb it goes black and refuses to power on.
What could be the reason for that? Physical (power button) or is it a programming issue (missing a software update) ? Thanks
but how do i open sansa clip to replace the battery of fix it
@miikerman wrote:
you could try prying the halves of the Clip open and then resoldering the battery lead (or gluing it with conductive epoxy)
