I used a Scandisk 8Gb USB & installed the secure access feature. This has in turn encrypted all of my pdf files on my Samsung Note 10.1 that was connected to my PC at the same time. I can see the files on my 10.1 when using it’s own screen but cannot see them from my W7 PC when attached or XP laptop. I have restored to factory the 10.1 but problem still exists. Any clues?
SA is a windows application. it will not even run on an adroid device so I do not think SA software could ahve doe this. If you do not need password protection you do not need to use the SA software. You can simply delete it. Once that is done retransfer the files and then put them on the Note.
