Hi.
I admit I’m very obtuse but I’m wondering where SecureAccess backs up the files I saved in my Vault.
To me, this vault already serves as a backup so I’m a bit confused where it stores the files next.
Hi.
in that case the backup goes into the %appdata% folder in your pc direct, so if you check there you will find a folder mentioning encryptstick and inside you will find a copy of the vault along with the encrypted files
