Since the sansa clip does not have a counting system, this script uses the rating system to determine which track to submit. If the user rating is larger than 0, the track will be submitted. If rating is 5, the track is marked as love. This means one has to rate the tracks if they want to submit, which requires some changing in the listening habit.
The script works in MSC mode only. It reads the MTABLE.SYS file under the root folder of the player. This file contains the information of the tracks when the player is mounted. So, DO NOT TOUCH ANY FILES ON THE PLAYER BEFORE YOU RUN THIS!
One has to change the global variables in the script.
to use:
python sansaclip_scrobbler.py [path_to_MTABLE.SYS]
Each time the script will reset all the ratings on the player.
depends on :
tagpy
http://mathema.tician.de/software/tagpy
to download the script
http://www.uni-ulm.de/~lhan/present/sansaclip\_scrobbler.zip
Message Edited by hanselda on 11-25-2009 09:42 AM
