screen turns off when plugged in
When i plug my Sansa Clip into the computer it says connected, then writing, but after a bit it turns off completely and ends up using up the battery more. It charged jus fine on my home laptop the first time i charged it. Help!!! What do i do? It won’t charge!
Are you sure that the Clip turns off? When charging via the computer, the Clip is set for the screen to turn off after about an hour, while charging progresses, to help preserve the life of the screen–you can get the screen back on (to check the charging progress, for example) by touching a button such as the center button. Otherwise, what USB mode (under the Clip’s settings) are you set to, MSC or MTP mode? If not yet set to MSC mode, you might try setting to that. Finally, if you are having a problem in connecting to your computer with the original Clip, you might try forcing an MSC mode connection: with the Clip off, put it on hold (so that the orange under the on-off slider appears) and then hold the center button down while you connect your Clip to your computer. I hope something here helps–
