Ok I just bought a Fuze and it’s been working fine until yesterday. I was playing with it and it was about to die (I could tell because the screen was going in and out) and I went to charge it and I let it charge for about an hour and when I went to turn in on, there was a blank screen but when the blue ring turns off, the screen comes back on, but it’s a little dim, and when the blue ring comes back on, it goes blank. I tried updating the firmware, reformatting it, and everything, and nothing works. Any help will be greatly appreciated. Thank you.
That is already a hardware issue. Call the vendor right away and ask for a refund.
You can’t really be sure with refurbished devices ![]()
Ok thanks! I’ll try to get a refund! Thanks for your help! Do you know if anyone ever had this problem before or is it just me?
Good luck. Re-furbs generally only come with what is referred to in the used-car-lot industry as a ‘tail-light warranty’. The warranty only lasts as long as the dealer can still see the tail-lights while you’re driving away.
Then he laughs all the way to the bank.
