has anyone found a good glass scratch remover ?
I could use something of the sort myself. Unfortunately, I don’t think that anything like that has been invented, else it would be very popular among glass owners.
You didn’t specifically state this, but if you think the Sansa’s screen is glass, its not. Just FYI. Glass is infinitely easier to keep smooth than the scratch-prone plastic we have.
If it is plastic in witch I would think it is. I couldnt see why you couldnt use something like meguiars PlasticX to remove the scratches. It depends on how deep the scratches are. I have used this product on my mothers Headlight lenses when they was cloudy. I used 2000 grit wet sandpaper to remove the buildup. Then the plasticX on a buffer to take the scratches out of the lenses left by the sandpaper. so I cant see the plastic x not being able to remove the scratches on the player screen.
I am not saying to use the plastic X as I dont know how it will react on the screen and have people say he made me ruin my screen. Just saying there are products out there that removes scratches on plastic.
USE AT OWN RISK!!!
as far as removing scratches off glass? I have heard of people using car buffing polishes to remove scratches off the windshield. But they say you can screw it up quick and not to attempt.
