saving video to SDHC card?
I recently bought the 2G fuze and was able to save a movie onto the actual player fairly easily using the media converter but when I tried to save the same file to a 4G HDHC card while it in the Fuze it just won’t recognize it…am i doing something wrong?
It doesn’t recognize the MicroSDHC card or you put the video on the card and the player doesn’t recognize it?
Click on the Card image in Sansa Media convertor to select the card.
If you cant do that then there is a problem with the card.
