Saving unnecessary book samples
Hi - I listen to a LOT of audio books. Before downloading them however, I often listen to samples of the book to see if I will like. I discovered today, that ALL of these short 2 minute samples been saved to My Book portable drive for the last millenium. Is there a setting I can use so that this does NOT happen. I really don’t need all of those samples. Thanks in advance.
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
To Contact WD for Technical Support:
http://support.wdc.com/contact/index.asp?lang=en
Are you backing up with Smartware?
Joe
I have emailed the tech support people. Await answer. Thanks.
Smartware is the software that comes with device, correct? If so, yes, that is what I am using.
I take it you save those sample files for later listening. Create a folder for saving just those and see if there is a way in Smartware to exclude that folder.
Joe
