I just purchased a new Fuze…and when I plug it in, the computer constantly reboots until I unplug it. I use Win XP.
Thanks for any help that you may provide.
Darryl
Darryl
Try switching the player to MSC mode in the SETTINGS > SYSTEM SETTINGS > USB MODE and see what happens when you connect to the computer.
The same thing just happened when I plugged in my camera…so it appears to be a problem with my USB/computer. Thanks for the reply, though.
@digitaleargasm wrote:
Darryl
Check your service pack, I had a similar issue before SP2. If you have SP2, then try getting SP3.
