I have a Sanza fuze and trying to convert video file using media converter. However, upper bar seems to show that 100% of file complete and lower bar that only 49% converted and then stops. The upper bar always shows a percentage which is double that of the lower bar. Anyone have same problem and know how to deal with it.
have you tried converting video to AVI format, that seems to work
The movies when I download them are already in avi format.
ARe these movies downloaded from sites you bought them from? For some reason you can’t convert those. Same with rental movies and protected movies.
YOu need to convert your own dvd an then use SMC (newest DVD’s don’t work all the time though).
