I ve got problem using a micro sd card in my sanza. I had to make a reset.
Was it because of the battery life ? does the micro sd card use more power to work ?
Joe2112 wrote:
I ve got problem using a micro sd card in my sanza. I had to make a reset. Don’t worry, this isn’t serious.
Was it because of the battery life? I doubt it.
does the micro sd card use more power to work? Slightly more, yes.
