Sanson clip 2gb charging problem
okay, so i am able to sync music to my player, but it wont charge.
it keeps showing the writing, the connected, then the start of the sanson good bye. I wont charge and i need it for work! can anyone please help???
Try different USB ports.  It may be that you have it connected to a low-power port.
Have you tried a wall charger (AC adapter)?
I have the same problem. It’s conected ,but won’t charge, so when I dissconect it from the USBport it turns of:(
Have tried diffeerent USB ports…
Is yours a refurbished Clip?  Maybe bought from woot.com?
