After downloading audiobooks and transferring to my sansaview when trying to play I get an error message ‘not activated’ Any help would be much appreciated
regards
Brian
regards
Brian
What is the source of the audiobooks? Are they DRM-encypted? Sounds like you need to authorize the player to play these “protected” files.
Audiobooks are downloaded from Audible.co.uk
Have you downloaded the appropriate software from Audible?
Have you read any FAQ’s or instructions on how to use the service?
Is your View player set to MTP mode for the DRM-encrypted proprietary Audible files?
yes
yes
not sure how to check this
