Some time Every sansa Device crashes or gets stuck on loading screen for hours and days
Computer Cant Connect to Sansa while loading screen stuck
shutting off the device for 10 secs
Reset Device for 20 or 30 secs
If that doesn’t work
Try this
Connect your sansa Device to a Ps3,Xbox360, or any other that has ports for connect
The Sansa Device will connect and show Pictures/Music/Videos
for this guide you need to delete all pictures,musics,video.
when your done deleteing Unplug the cable cord The sansa will turn off if it doesnt hold the power button for 10 sec
Power up the Sansa device and the Loading Screen will be Finish faster
Once you are on the menu Find setting and Format and your done
Try Asking a Friend or family to use ps3 or xbox360 or others that connects to sansa
If this Guide Didn’t Help Contac the SanDisk.![]()
