Hi, I know there are a lot of topics about problems after having washed the SansaClip. However, I think that my problem is a bit strange.
I can turn it on and it works but after some seconds playing a track (0:10-0:20…) the track starts again and this happens every time.
Can it be solved if I dry it(with rice for instance)?
Thank you
You shouldn’t be turning the player on, which can damage it. Yes, put it in a warm location, and/or in a bowl of rice, for several/many days, and do not try it again until it is fully dry.
Each time you turn it on it may be shorting out because it’s still wet inside. Dry it out before you wreck it, if you haven’t already.
And if you read the posts and knew about rice…it was kind of silly to ignore them.
