I had the old media converter. The one that showed a picture of your player, when you had it plugged in. I can’t get the new one to do right. I would like to have to old one back. Where can I get it?
Have an mobile phone and wonder how to enjoy your favorite funny videos on your mobile phone?
Now this article is created exactly for you to show how to put videos on mobile phone step by step.
Tool you need: iOrgSoft 3GP Video Converter
Summary
Step0: get your tool
Step 1: Load video info
Step 2: Video Edit
Step 3: Video /Audio settings
Step 4: Set output format and destination path and Start Conversion
Now let me show you how to do it in detail
Step 0: get your tool
Free Download this video to mobile phone Converter software, and install it on your pc
To load video info, click the Add icon and select the file in the pop-up Open window. It supports you select many files to convert at one time.
Step 2: Video Edit
Click Edit button in the main menu to check the trim contents and function. There are there functional bars for you to edit the video. The slide bars beneath
the embedded player screen enables you to crop the black edges of the video.
1. Video Cropping
Click Crop in the Video Edit window. You can use this button to crop the black edges appear in the movie. You can use it to define the range of the movie
that needs to be converted. To crop, you can either drag the white-dotted line in the screen or you can just set the accurate numbers in the left panel ( Up,
Down, Left and right) by hands. At the same time, you can select an output aspect ratio from the Zoom list. There are four choices available: Original, Full
screen, 16:9 and 4:3. Click Reset to cancel action.
2.Effect settings
Click Edit button to check Effect in the pop-up Video Edit window. Our iOrgSoft 3GP Video Converter allows you to set brightness, contrast and saturation.
You could set the effect as Gray, Emboss or Old films and then adjust it to get the best effect as you need.
There are another other two icons: horizontal flip and vertical flip. They are enabling the movie so show as a image-reversed play mode, try them now to
enjoy the fun.If it is necessary, you may click Reset to cancel the settings.
3.Movie Trimming
Set the start time and ending time to define the length of the video that need to be converted.
Set start time and ending time
You can select the start time and ending time by hand at the left panel by tuning the numbers. Or you can just drag the slide bars beneath the screen directly. After you finish the settings, the length of the captured video will be shown in the selected length box for your reference.
Preview video
Preview the selected video file with the tiny screen to estimate which part of the movie you want to convert.
Click the setting button to set specific output values both for Video and Audio.
Video
Set video encoding settings by selecting a resolution, a frame rate, the encoder and a bit rate on the right section.
Audio
Set audio encoding settings by selecting a sample rate, an audio channel, a bit rate, the encoder and an audio volume.
Set an output format for the selected file.
Click the first icon to specify a folder on your computer to save the converted file. You can open the output folder by clicking the Open button.
Start Conversion:
After all the setting work is done, you are set now. Click Start in the main menu.
To sumup, iOrgSoft 3GP Video Converter is a professioanl yet easy to use converting tool. You might need it when you want/need to rip and convert dvd to AVI, MPEG, iPod, mobile phone, PSP, Mobile 3GP, WMV, Zune, FLV etc. . High quality and super fast conversion speed, often a DVD 9 disc was completed in about 15 minutes. You can get its full version now HERE at a very competitive price, or see more details.
Free Download iOrgSoft 3GP Video Converter to try Now!
Get the Full Version to convert your video to Mobile phone NOW!
Hi There,
I’m having the same problem!!! PLease can you upload this link to download the old version of the sansa media converter.
Thanks Denise
denise1211 wrote:
Hi There,
Thanks Denise
What’s wrong with the link in my previous post?
Where do you go to download it?
