Sansa media converter has dissapeared from your web site
I went to download the media converter from both teh scandisk downloads site and the sansa site and its not there any more - it was last week.
How can I get a copy of this software ?
regards
Terry
I found it for download at: http://mp3support.sandisk.com/downloads/smc-4.236.exe
But I had to get that through support (MP3 Players: Shop Our Clip Jam to Bring Your Songs with You | Western Digital).  I haven’t installed it yet though (its still downloading).  I’ll try to come back and let you know if it works.
Joe
The program seems to be working fine for me.  It converted a couple videos (WMV’s) with no issues.  I’m going to try some MP4’s and AVI’s next, but this seems to be working.
Joe
I converted an MP4 and an MOV without issue.  It complained that it didn’t have the codec to convert my AVI, but that was probably saved as a Divx AVI.  So that might be an isolated issue.  I’m sure there are AVIs that will convert.
The point is, the program’s been running well for me.  I’m on a Windows Vista Home Premium machine.
Good luck!
Joe
Thanks Joe  I’ll try downloading from there
Edit - yes that worked just fine - sorted
Cheers
Terry
Message Edited by Riggers on 06-04-2008 07:19 AM
I’ve been using it fine also-
I just hate having to use DVD decrypter to get movies off MY DVDs then use Any Video Converter THEN use Sansa Media converter…
takes forever…
