I have had this mp3 player for 6 months. From the beginning everytime that I would connect to the computer, a bar would show up at the bottom of the computer screen saying autoplay. I would click it and a window would open up with the options to sync to windows media player, sync to Napster, or open to view files and a few others. Now all of a sudden the only thing that shows up in the window is open folder to view files and speed up my system. What has happened to this helpful window and how can I fix it back
Ah, the AutoPlay function suits your fancy? You can turn that on if you wish, or specify what you’d like your computer to do.
Plug in your Sansa.
Press the [Windows Key] + E, or go to My Computer. The Sansa will show up.
Right Click on your Sansa, and select Properties. Then select the AutoPlay tab. If you check the button at the bottom, “Prompt me each time to choose an action”, there you go!
Bob :smileyvery-happy:
I did exactly what you said but no autoplay tab appeared.
Are you in MTP mode? You mentioned Napster.
Bob
