sansa Fuze srceen help.....
when i push down on my screen or on the sides of my player it goes in a little and makes a sqeaky type noise…
is this normal
is this normal
Uh…   can you give more information…
Why are you pushing down on your screen?  If you push hard enough it’ll bend…  That sounds normal to me.
About the noise, I don’t know…    How loud is the noise?
