Hi, I just got my sansa fuze 8gb (black) and the wheel makes a light squeaking noise. knowing me, the slightest thing will bug me once I figure it out (like noticing the refreshes or bad colors on a cheap TV). So, my question is if it goes away after use. Did you have this when you first got yours? Should I return it?
I’ve had mine since the Fuze came out and I don’t have any squeaky sounds from the wheel. My parents also bought one 3 months ago when I was visiting them and they did not have any squacky sounds coming from the wheel.
So my guess is that you just have a bad Fuze. Return it for another one and hopefully that one will be just fine.
