Oh well, no one is going to get to the finish line (100 pages). :smileyvery-happy:
If you are really craving for 100 pages, you can edit your preferences and show less posts per page. Enjoy!
That is the post of the day!
is it possible to get the version 01.01.22 back on my fuze? i wnat to use rockbox but was told that it wont work with version 02.01.17. its either that or is there a mystical (hardware) first version?
Firmware starting 02. means you have a ‘hardware revision 2’ device. You can not install 01. firmwares on it and it would not help anyway.
Rockbox only works on ‘hardware revision 1’ devices (the original Fuze). There is little movement on getting Rockbox to work on the ‘revision 2’ hardware because the hardware is different and I don’t think any of the active developers have a ‘revision 2’ device.
OK i have a problem my friend has a new sansa fuze update (and me too)but i dont like this because the sound is sooooo bad now and my question is can i get the old update or sth back because i like metal soos bad and now i cant listen the song correctly:D
So does sb can help me?Please!
The sound quality should not have been affected by the firmware update. If by “bad” you mean the volume is lower and you selected Europe as your region, try this.
ok i got my Sansa fuze about 5 months ago and i just update it and i DONT LIKE IT AT ALL and i just want to know that can i get a old update back or sth?
Right now i have update V01.02.31F
So i hope sb can help me and maby sb could send me respond as a message (because i am new and i dont feel so good at this foorum yet)
Yes, you can “back-date” the firmware. If you go to the 1st post in this thread you’ll find the previous firmware version.
But what is your problem with the latest one? What don’t you like about it?
This is a user’s forum, but if you want you can call SanDisk Tech Support and you can speak to them directly.
