is Music Go List now always at the top of the playlists view or is it just me?
First, thanks for the update - the previous method of locking was very bad, many times I accidentally paused playback when I wanted to lock. I like the 24-hr clock too, and I am looking forward to the promised changes such as folder navigation and in particular the looped menus.
Now, on to complaints
“The format of the date setting will change according to region North America: MM/DD/YY; all other regions: DD/MM/YY”
Is date ever displayed or used except in date settings?
How do I set my region to have the date displayed as DD/MM/YY?
I don’t understand why it takes so long for the volume buttons to start working after the player is locked.
More importantly, it takes long time for the volume buttons to start working after the touchpad was touched while the player was locked. Does not make sense to me. If I have the player in my pocket and it’s locked, and I want to change the volume, it is quite likely that I will inadvertently touch the touchpad while reaching for the player. This disables volume buttons for an annoyingly long time.
I agree, the behavior of the dedicated volume buttons when locked is incorrect. Any time the “locked” message displays, the controls are inhibited for about 40 seconds. The lock feature should not affect the hard buttons, just the touchpad.
It’s quirky that if the touchpad is not touched, or even the power button is touched, actually- as a brief tap of the power button will elicit the “locked” screen display, starting the 40 second inhibit all over again.
The threshold for the lock function is about 500ms (1/2 second). A brief press of the power button (above this time) will toggle the lock on or off. If the button is merely tapped, the “locked” screen displays. Obviously, there’s a little learning curve here, but it’s not so bad overall.
If the volume buttons are operated after about 40 seconds, they work normally when locked.
Bob
I just got mine, and as per the directions, I downloaded the “Updater” which handled the firmware update. When I started, the version on the Fuze was 1.27. After the update, it is now 1.32.00A. So. What is this version 2.36.03? Should I trust the updater, or what I see here. Out of curiosity, I tried the power button to unlock the thing, and it has no effect. Is there some kind of two-tiered system that isn;t in the advertizing?
The Sansa Updater follows the Forums by a few days. Download and install the new version here via the firmware link, and use the manual installation process. Be sure that the microSD card port does not have a card mounted.
You can install the firmware.sb file in either MSC or MTP mode, whichever mode you currently use will be fine, I’ve tested transfer in both venues.
By installing manually,you’ll heve the new lock function and a selectble 24 hour clock too.
Bob :smileyvery-happy:
Yes, I also would like to know : “How do I set my region to have the date displayed as DD/MM/YY?” Thank you in advance for responding to that.
For the other features, all is OK for me in this new release (even if I’d no problem with the previous locking feature).
Thank you to Sandisk to ear its customers, and it is really useful to have this forum to have the information and share experience with other users.
After two weeks with my Sansa Fuze+, learnig how to correctly use it, especially convert and tag my content to see it correctly ordered in my Fuze, I really love it.
After testing different software to tag content, finally I found the best is MediaMonkey. Perhaps it will be usefull for “newbies” to know that
Bob
I still need to question: going from version 1.27 to 1.32 seems kinda normal. From there to 2.36 in “a few days” seems far fetched. It still seems like there’s something not to trust in this. It is a brand new Fuze+, which seems to be what I am hearing about here, but why would the installer program make a normal incremental move as apposed to this version jump?
@davcbr wrote:
Bob
What Bob meant was that the newer firmware update has been posted here on the forum as soon as it was released. It just hasn’t been updated to the Updater yet. That will happen in a few days, barring any catastrophic issues that are discovered by those here who downloaded it first.
Members (and visitors) here always get a few days advanced access to firmware updates before the general release.
is it just me or deos it not keep time anymore? I turned it off yesterday at noon and booted it up now and it said it was the time I turned it off?
The build revision numbers reflect various internal coding changes in the firmware. SanDisk tests various builds and releases the final versions after testing. Often, there are intermediate builds that have different individual functionalities.
Rather than renaming the final release in a direct numeric sequence, the build number remains intact. That’s why we’ll see jumps in the firmware version number. These little players handle so many different applications and file formats, depending upon the user’s needs and preferences, so the firmware can be quite complex.
Often, the leading digits of a firmware designate code written for different revisions of the hardware. Over time, inprovements are made at the hardware component level, necessitating a firmware change specific to the new revision. In the case of the Fuze+, the change in the leading digits reflects a new family of firmware, not a build specific to one hardware revision. That’s why the firmware will run on the current devices in the field.
I had wondered if some of you who have had rev.1 and 2 Clips or Fuzes might have been concerned about that. A good way to think of it is the 02 firmware incorporates the new key lock function.
Oh, sorry, almost forgot. Selecting the 24 hour format does not switch the date format to DD/MM/YY, European-style, like it does on my cycling computers. I like that, actually: when selecting km as the default speed indication, many cycling computers then flip the date format as well as add a 24 hour time display. Not so with the Fuze+, as the date remains MM/DD/YY regardless of time preference.
Let me know if your clock’s “suspended animation” has resolved, it sounds like a glitch. Is the clock keeping time once again?
Bob
In Canada we use DD/MM/YY, or YY/MM/DD, i.e. NOT U.S. style format. What you folks call “European” I guess. So, how can I fudge the Region setting, as I cannot find anything in Settings? Some of us Canucks also use 24hr format regularly.
Perhaps you could add the ability to change specifically the Date Format in a future firmware?
Thanks,
Negitive. I turned it off after posting then picked up again an hour later and it said it was an hour earlier. The date also sticks which proves the time isn’t ticking. It’s @ 50% charge if that mattters.
I see I and my Fuze+ clock are in good company. Since installing the latest firmware, my clock does not update properly either. I have the impression that it even runs backward sometimes. With the last firmware update, my clock was a bit “flakey” for a while, but it seemed to straighten itself out in time. No indication that it is going to self-correct this time. At least the sleep timer does apperar to operate correctly.
the constant reboot bug with certain flags IS NOT FIXED.
And not mentioned under known bugs.
Hey, Sandisk, are you kidding me? There is a german word which is very fitting for your behaviour:
VERARSCHEN
And I haven’t even tried playlists. If you can not fix constant reboots, I am sure you are completely unable to fix a ‘lockup on non-windows-7-generated-playlists’.
mine only keeps time when it’s powered on so sleep timer works (thankfully). No backwards tome counting though.
how are you turning it off? i just turned mine off for an hour and it has the correct time.
hold pwr buttin for 3-4seconds release it says good bye and then shuts off.
hmm i am not having the same issue. few more questions.
are you using 24hr clock or 12 hr clock?
what region are you set to?
12hour US
Mine doesn’t keep time no matter how I turn it off – long press of top button or with sleep timer. Using US 12-hour setting.
