When I try syncing my music files using Napster, all my files are getting transfer error messages. I’ve tried formating the MP3 player and made sure that I have the latest firmware, but I’m still getting transfer errors.
Any ideas ???"
Any ideas ???"
yes you first make sure it is in the auto detect mode in the settings of the player then go to tools tab in rhapsody click on preferences make sure the fuze is conected then when the scrren pops up click devices then advanced setting then make sure the cache option is clicked the click delete files now and that should solve the problem
Yes make sure the mode is MTP, checking it under System settings and go to USB mode and select MTP.
MTP is a media transfer protocol that is use when transferring License songs like Napster and Rhapsody.
