Sansa Firmware Updater
My Sansa Updater shows there is no new firmware to be updated and that the latest version already  installed is 1.02.17.  However I believe there is a 1.02.18 which does not show on the Sansa Updater installer.  I have d/led it but am hesitant to install it without the Installer to do so.  I would not know where to copy it to.  The Clip works fine as it is.  Should I leave well alone?
Sorry forgot to add its a clip+
The manual installtion directions are in the firmware post here on the forum. You don’t need the Updater.
But the .18 release is very minor. It’s unlikely you would see any difference or improvement over the version you currently have on your player. I wouldn’t bother updating.
