Sansa express not accepting more then 128 files
When I drag and drop mp3-files to the Media folder of my Sansa Express, I get an error message after 128 files saying
“The file xxx.mp3 cannot be copied. It may already exist or is in use by another programm”.
(Hope I translated this correctly; my OS is not in English)
The Sansa Express doesn’t accept any more files in the Media folder, nor in the Data folder!!
System info on the Sansa Express reads:
Firmare: 01.01.01F
Memory 974MB
Free 865MB
Songs 128
WinXP SP2 - Media Player 10 - Sansa Express 1GB
Tried format, reset, hardware reset. No luck.
I had the same problem with drag and drop.  I worked around it by using WMP10, and using the sync function.  Another thing that may work though I have not tried it, is to make the device work in MSC mode and try to drag/drop again.
Tried both solutions, without succes :cry:
format it to FAT16…
see if this works.
try to make a folder, which named ‘audio’, in the device and try again. I had same problem, and I solved that way.
Message Edited by hcgt on 09-01-2007 12:04 AM
or you may need to reformat to fat32 or format in WMP10/11
I had same issue.  They are correct.  Create a folder and place files in there.  Works like a charm.
Just don’t update the firmware.
Thanks, all of you for your replies. Finally found out what was going wrong. The media folder acts like the root directory, having limited capacity. I dropped individual files in this folder, with the known consequenses. The trick is indeed to create a subfolder in the mediafolder. Works like a charm indeed, even with the upgraded firmware. Manual is misleading about this issue IMO.
