I own a Sansa fuze and I use the Sansa Eabuds I bought with the fuze to listen to. Today my earbuds wont work. If I put my earbuds in the socket in the fuze and turn the volume full blast I can just bearly hear my music. If I plug my earbuds in halfway into the socket in my fuze it works fine. I tryed other earbuds and they work fine in the fuze. Is there anyway to fix this problem?
Make sure they really are in all the way. Push really hard. If not try some other earbuds. If you get the same results call tech support.
