I need help in getting music from my computer to my SD card for my e140. I"ve done this before but don’t remember how… Can someone step me thru it, pls?
Thanks.
Deb
Thanks.
Deb
Real easy - just makesure the SD card is in the e100 when you connect it to the computer. You know how the e100 shows up with a second drive? That’s the card. Just copy your music to the other drive. If you’re not sure which drives are the player, just have My Computer open when you connect the player, and watch for the two drives that show up. The first one will be the player and the second one will be the card.
