sansa crashes computer
when I plug it into the computer via usb to charge it, the computer crashes! what can I do that will make the computer stop crashing when I plug it in? Is there a different way to charge it? Plugging it in the computer is the only way I have to charge it that I know of… does anyone else have this problem?
If a USB device can crash your computer, its in bad shape. I would format and reinstall windows.
My husband’s sansa fuze+ doesn’t do this when we plug it in, or his kindle, but my sansa clip does. Are there firmware issues with the sansa clip that could cause this?
It may be a computer hardware issue with the USB connection–have had that on IBM Thinkpads in the past (a known issue).  You might try another USB port.
Or a different cable. A pin might be bent or wire(s) inside broken or touching shorting it out.
Quite so!
