hallo my charger has 1000 mA can i use an 1500 mA or 2000 mA charger for loading . without this clip zip mp3 player break ?
Yes.
As noted above, yes: the Clips want 500mA or more of amperage (current), although they can live with less (to around 350mA or so). Having more than 500mA of amperage will not have any adverse effect on the Clips, as they simply will take the current they need (in other words, you don’t have to be concerned about “blowing the Clip out” with too high an amperage–as distinct with voltage, where you want 5V and where more indeed will fry the Clip).
