Sansa Clip Zip, adding a digital output ?
Hello If I’m correct, the DAC is part of the SOC in the Sansa Clip Zip. Is there a digital output on the chip in the Sansa Clip Zip ? How can we add a digital output to the Sansa Clip Zip ? Thank Bye Gaetan
In theory you could output digital audio over USB and then connect a USB DAC. However, it would not be trivial to write the driver, at least without you already knowing quite a lot about USB. Aside from that, I’m not aware of any other digital bus that can be accessed on the Zip.
