Sansa Clip+ Voice Recording Long Periods
Hi All
New to the forums but cannot seem to find the answer to my problem.
I’ve got a Sansa Clip+ 4GB, I do a lot of long recordings with it at lectures, sometimes over 4 hours or more, the microphone on it out performs any expensive dictaphone and picks up voice very clear even from about 10 metres away at the back of the room.
However the problem I have is that I can fill the internal memory up in a day and I’ve not got access to a computer or time to backup audio recordings as I listen to them on the actual sansa.
What I’d like to know is there a way to set the audio recordings to record on the memory card slot? as I have a 32gb microsd card that I could use.
If anyone could help that would be great, I have considered buying  an 8gb model but It seems pointless outlaying another £35.
Thanks in advance.
Peter
Unfortunately, no. The player will record to the internal memory only and stop recording when that space is filled. The only way to record longer is to buy a player with a larger memory.
You might want to explore the alternative Rockbox formware (at Rockbox.org), as to its recording capabilities–as I understand it, Rockbox allows you to set where you want to store recordings on your player.
