Hello everybody, I have corrupted firmware on my Sansa Clip but i can’t update it because my Computer will not recognize my Sansa Clip. I need the Driver Files for Windows XP so I could update the drivers. Thanks
The MSC driver file is part of Windows, the MTP driver part of Windows Media Player 10 and above. Windows should be able to install from within itself.
mi sansa no se conecta a la pc
You might try a different USB cable and/or different USB ports, and see if that helps.
