@tk1 wrote:
YES I did notice it and read it, just want to know how to use the ***** thing.
Thanks
What are you trying to do?
Thanks
Thanks
Unfortunately, that is the only formal manual there is, and SanDisk hasn’t updated it (and it was brief on some topics to begin with). You can ask questions here, as noted above, or do a search using the upper left search box. (And I assume you know that you can save the manual to your computer as well, to read at your leisure.)
The link to the manual for the Clip on the first page of this thread is broken! Is the manual still available?
Dang–how special. _ SanDisk, please fix? _
In the meanwhile, I can email you a copy, if you send me an email with your email address (use the envelope icon at the upper right). Unfortunately, SanDisk has not kept the manual up-to-date, and it had some lapses to begin with.
Just updated the Sansa Clip User Guide link for you. Thanks for mentioning the link issue!
µsansa
hi there i am a newby and would i love u to answer a problem i have have looked for the answer on the community cant find the answer i am sure that it is simple but i cant work it out.
i have deleted the music on my sansa clip 8mgs, on media player still says the songs are on there. answer my problem please need it for my hols in 4 weeks. i have windows xp. thanks again emerald
i thought it had changed my life to until i tried to delete the music my media player says its still full. just lost for words any clues how to resolve this please i have windows xp thanks diane
An easy thing to try: on the Clip’s Settings menu, select format. That will erase all the files you put onto the Clip.
Also, in the future, it may be better for you to start your own thread with a question. Among other things, helps you get responses.
the general information isnt that bad, but I´m looking and looking… and can´t find an information about the earphonesocket. Please can someone tell me the resistance off this earphone outlett.
Thanks Gambler
If you mean the impedance, I believe it’s 16 ohms. That seems to be the same for all Sansas.
If you mean the effort needed to insert the headphone plug, it’s higher when the player is new, and decreases as the jack is “broken in”. Many people have complained of sound problems (mono, instruments only ( “karaoke effect” ), or popping/crackling in the phones) only to learn that they hadn’t fully inserted the headphone plug.
thanks for your answer, yes I´m looking for the impedance. There is an different answer in an other Thread with the same question. There is told that the impedance is about 10 mOhm and has a phantomground (virtual ground). Would it be possible to verify this 2 different answers so that only 1 can be right?
Greetings Gambler
PS. My english isn´t that good, because it´s not my first language, but I hope it´s understandable.
Yes,I agree with you they are a profit company.IDK if they are really concern with the users.
Without the users there would be no profit so yeah, I’m sure there’s some level of concern there.
Who are you agreeing with? You realize this thread had been inactive for nearly two YEARS before you posted, right? Whoever you’re replying to may not even come here anymore.
I salute this clip!I just read this today!I’ll try this later on.Thanks a lot!
It seems that the forum recently has been the beneficiary of a handful of new uers who are posting for posting’s sake (I haven’t the foggiest idea why), often resurrecting old threads and adding little or nothing. I guess it’s raining outside?
School’s out.
I believe at least two of them (MikeCorleone and VitoCorleone) are the same person. Perhaps his attention span was too short to even remember the password to the first account?
In that case, I have the perfect password for him/them…12345!
:smileyvery-happy:
To operate in MSC mode on a Windows PC, one doesn’t need Windows XP at all.
