What is the MAX Card that can be read in a Clip? I wants to buy a 2GB Clip & a Mini SD Card to go with it.
The clip does not have an expansion card slot. The Clip come in fixed memory sizes and available in 1,2,4 and 8 GByte models. If you wish an expandable memory mp3 player look into the Sansa Fuze or Sansa View.
Cheers
I looked in a UK store catalouge last night & saw the Clip & the Fuze advertised. http://www.argos.co.uk/static/Product/partNumber/5138269/Trail/searchtext>SANSA.htm & http://www.argos.co.uk/static/Product/partNumber/5138283/Trail/searchtext>SANSA.htm
They BOTH say the same size lol.
What size is the Clip?
Other than Size of Unit & SD Card what is the difference between Fuze & Clip?
- What size is the Clip?
- Other than Size of Unit & SD Card what is the difference between Fuze & Clip?
Very small. In iPod terms, about the size of a Shuffle.
The Fuze has a larger screen and plays video and pics.
You may want to check out the product descriptions at the sansa store, using the link at the top of this page …
Thanks
Last question
How long does the Clip take to Charge via USB (PC) or USB (UK Power Converter). I read that the Clip has to be ON to Charge (not like Mobile Phone). But how many hours would a charge to?
Thanks
Last question
My charge times were between 2 1/2 hours and 3 1/2 hours for a fully dead battery. There maybe variation between clips. Most of the time my charge time is less than this, because I plug it in when its partially charged and it doesn’t take as long.
Thanks
Last question
The Clip will turn itself to on when you hook the USB cable up to recharge it.
