After some months usage my Sansa Clip+ not possible to power on… Its fully charged and its connect to pc and show full battery… When i remove connection playr is off and not possible to turn on power. I have try reset several times but its not helping ( i have used reset earlier when had some issues)
Regards
Nikki
If this is one of the orginal Clips (round scroll wheel, no SD card slot), they were prone to faulty solder connection on the battery leads. If your player fires up when connected to your computer or a power source, but shuts off instantly when you unplug it, it sounds as if this is what might have happened.
hello, my player dont have round scroll wheel… And i do have sd card slott
Nikki
ok thanks for the reply… Whats the best way to open the player?
Nikki
Nikki
These YouTube videos should help:
https://www.youtube.com/watch?v=beMcITVdZcE
https://www.youtube.com/watch?v=zN-b0AfiQnU
i got it open…and was able to turn it on direct without the butto on the shield…so i put it back and it worked a day,then button not work again…What should i do to fix this permanent?
Nikki
