# sansa clip not play flac frimware is 1.1.30f1 how fix it
**URL:** <https://forums.sandisk.com/t/sansa-clip-not-play-flac-frimware-is-1-1-30f1-how-fix-it/45088>\
**Category:** Sansa Clip  |  Clip+\
**Created:** [February 17, 2009, 1:54pm UTC](https://forums.sandisk.com/t/sansa-clip-not-play-flac-frimware-is-1-1-30f1-how-fix-it/45088 "2009-02-17T13:54:18Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![ashkan](https://avatars.discourse-cdn.com/v4/letter/a/67e7ee/32.png) [@ashkan](https://forums.sandisk.com/u/ashkan)\
**Post date:** [February 17, 2009, 1:54pm UTC](https://forums.sandisk.com/t/sansa-clip-not-play-flac-frimware-is-1-1-30f1-how-fix-it/45088/1 "2009-02-17T13:54:18Z")
</div>
hi all
i need software for convert mp3 to flac,plz guide me .because i want test flac on sansa clip
Thanks
**Author:** ![skinjob](https://avatars.discourse-cdn.com/v4/letter/s/258eb7/32.png) [@skinjob](https://forums.sandisk.com/u/skinjob)\
**Post date:** [February 17, 2009, 2:56pm UTC](https://forums.sandisk.com/t/sansa-clip-not-play-flac-frimware-is-1-1-30f1-how-fix-it/45088/2 "2009-02-17T14:56:41Z")
</div>
It plays FLAC just fine.&nbsp; There’s likely a problem with your files.&nbsp; Either they are not properly encoded or you are using ID3 tags.&nbsp; The Clip only supports the normal Vobis Comment tags for FLAC/Ogg.&nbsp; MP3Tag should be able to fix your tags if that’s the problem.
Also, there’s no reason to convert MP3 to FLAC.&nbsp; It will sound the same as the MP3 but you’ll have much bigger files.&nbsp; If you want to get the benefit of FLAC (or any lossless format) you need to rerip your CDs.
**Post date:** [February 17, 2009, 6:48pm UTC](https://forums.sandisk.com/t/sansa-clip-not-play-flac-frimware-is-1-1-30f1-how-fix-it/45088/3 "2009-02-17T18:48:41Z")
</div>
hi skin job thank u
i want that test playing flac file on sansa clip . so i try mp3 convert to flac via other software. or rip music to flac if it is posssible via meial player 11 or winamp. because i have not flac file for my testung,&nbsp;
another problem winampe automaticallluy&nbsp; close&nbsp; when i synchrinise with sansa clip!!!
&nbsp;i wish that sansa solve voice recorder bitrate and format file becuse it has&nbsp; very weak option on this field,
&nbsp;option
with my best regards
