hi,
i’m a guitarist and i thought that it would be great and really helpful to have a metronome installed in my clip(and i would save the money i’ d use to buy a metronome)…so do you think this would be possible and how can it be developed ??
hi,
If you can borrow one maybe you can record different speeds and save them
rockbox have this feature… i’m not sure if they already released the firmware for the clip. you might want to check it yourself
Now THAT’s (low-tech) common-sensical problem-solving!
i meant an application,no mp3 files…i had searched the net and i’d found that solution but i thought that an application would be much more convenient…anyways the mp3 files should do the job…thanks for helping
