Sansa clip keeps disconnecting
Ok guys I got a question. Ever since I upgrade the firmware from the original to the latest Ive been getting problems with my clip disconnecting from my headunit in my car. I only use my clip to play music in my car and everytime my Pioneer headunit trys to connect to it it always will say writing and then disconnected even though I never unpluged it. It never did this before I installed the latest firmware. Usually it will still work after a couple of seconds to minutes of it writing and then disconnecting. Sometimes I will have to reset it for it to work properly. I was wondering is there anyway to restore back to the original firmware or anyway to fix this writing then disconnecting problem???
