In the post that starts this thread, follow the Manual Install instructions, which are roughtly: Download the latest firmware (look for an All Regions link), which is a .zip file. Unzip it. On the Sansa go to Settings/System Settings/USB Mode, write down which mode you had it in and change it to MSC.
Open Computer (otherwise known as Windows Explorer) and connect the Sansa to the computer. Drag the files you unzipped directly onto the driveletter for the Clip. Disconnect it (by taking the connector out of the Sansa first, not the computer) and it will update.Change the USB Mode back to what you had before.
The updater tries to contact Sandisk every time you boot up to see if there’s an update. All that does is slow down your startup. If you’re really worried about missing an update, check in here every now and then–but as you can see from the initial post, there hasn’t been a firmware update since August 2012, which means it’s pretty unlikely there will be another.
After doing a Firmware Update 01.02.18 on my Sansa Clip+ I am unable to make Playlists anymore…Whats up with THAT???..What good is it if I cant setup Playlist??? Do i need a driver for my OS???Help Please…My OS :Win7 With sp1
Also in settings >USB auto detect mode Win7 can’t recognize it…the only way it can is when it is in USB MSC…Any help would be greatly appreciated…Thx so much
So many popular editing tools and media players are available.
Easy operation workflow and faster conversion speed.
Extra acceleration function for Mac users.
Strong ability of setting and editing output videos.
Before May 7th, you can get a discount on Pavtube Mac products mentioned above. Why not take a close look at this 30% off event and seize the chance to buy excellent products with such pretty attractive price?
Around here the auto detect mode is called auto defect. a Clip+ should be set to MSC or if someone needs to use protected files, then MTP mode. If you are serious about using playlists on the Clip+, I suggest that you install the free Rockbox firmware on your player. It allows great flexibility in making playlists on the player itself, and many other great features. rockbox.org
We suggest you update the firmware through the Sansa Firmware Updater. If for any reason the Sansa Firmware Updater does not work for you, feel free to continue by trying the more "computer savy" steps described below.
Sigh … :neutral_face:
The Updater is not needed–it simply downloads the latest firmware for your player, which is readily available at the firmware sticky thread at the top of this forum. :) Likewise for the manual.
And with the way the Updater works, you’re actually better off installing firmware updates the manual way. The Updater searches for updates every time you plug in your player. A waste of time and computer resources since there won’t be any more updates for this old of a model.
I just got a new (used) Clip+ 4gb. It has v 17 software on it, and it won’t permit Overdrive to transfer an audio book to it (can not create a folder).
Am trying to update firmware, but am flying blind.
downloaded the file, extracted it, got a file clppa.bin.
Tried dragging it to the Sandisk main entry on explorer. Nothing happens. Unplug it, clip goes to “music” which is empty. No messages that it is updating.
Tried dragging ot to the Sandisk “internal memory” folder. Nothing happens. Unplug it, clip goes to “music” which is empty. No messages that it is updating.
Is this a slow process? Do I need to drag and drop the file and then walk away? When is it time to unplug?
I had installed Rockbox.
Now I wanted to go back to the original firmware, but I made the mistake of erasing all in the Sansa.
When I download the firmware is a few mega, there is not everything.
Where can I find the complete firmware?
Thankyou
When I download the firmware is a few mega, there is not all.
Thankyou
It is impossible to delete the original firmware. Rockbox doesn’t do it, and niether can you.
One of the nice things about Rockbox is that you can boot either to it or the original firmware at will.To boot into the original (Sansa) firmware when Rockbox is installed, press (& hold) the left (REW) button on the player while turning the unit on. It will boot into the Sansa firmware.
To then boot into Rockbox, turn the player off, then turn back on using only the power button.
I can confirm this. Just replaced a dead battery in my 6 years old unused Sansa Clip+ and immediately updated its firmware to 01.02.18.
Constant crashing and restarting issue, regardless of whether playing the FLAC files from internal or external storage. Tested the FLAC files for corruption and they’re all fine.
I thought the Clip+ is having hardware problem and dying… Really? Never had any of my devices ‘broken’ just by leaving it like that for years…
HOWEVER, ALL THE ISSUES ARE GONE AFTER REFLASHING OLD FIRMWARE VERSION 01.02.16…!!!
Don’t throw your Sansa Clip+ yet, they’ve released a buggy firmware before ceasing development…!!!
