I got mine a few weeks ago and it dropped a couple of times. The radio recording doesn’t work at all and the voice recording only works if I rub the microphone first. Any fixes to do this or will I have to return it?
I love posts like this. “I dropped it and it broke. How do I fix it, or can I return it?”
If the voice recording works when you rub the microphone first, maybe you can get the radio recording function to work if you pat the front display . . .
Hey, Butterfingers! How 'bout ponying up and buying a new one? This “It’s not my fault, and it should have been made better to withstand my stupidity” attitude would really be funny if it weren’t so pathetic.
I don’t know if it will help, but: did you try a reset (hold the on switch uppermost for 15-20 seconds)? Unfortunately, the drops may have borked something.
Having klutz-like tendencies myself at times, I like my electronics in padded cases, my Clip included. Small devices just tend to fall …
