Hello!
Can you please provide a solution for my sansa clip, the issue is that it is not detected although the clip is charging when it is connected to the PC.
I can still use the FM radio, but I can not put songs as it is not recognized. I had tried lots of possible solution stated in this forum but of no luck.
These are the following solutions I’ve done, but still did not fix the problem.
MTP, MSC, Auto detect mode
Install firmware updater
cd installer (will direct you to firmware updater)
Windows Media Player 11
5. Winamp player
- Connect recovery driver
Any advices & possible solutions are welcome… Thanks!
Regards,
Pols
