Sansa 250r problems
I have a Sansa 250r that I have never had any trouble with until recently. I have several CD’s downloaded to my Rhapsody that I hadn’t loaded into my player yet. I loaded around 100 songs from these newly imported CD’s recently. None of those songs play on my Sansa. They actually make the player freeze and the only way I can shut it off is to take out the battery. I loaded them onto my Sansa using Rhapsody like I have in the past. Did I do something wrong?
Might be the memory is not enough for new files?
How can you tell if this is the case or not?
DO ANY ONE KNOW WHERE I CAN GET THE PARTS LIKE THE SCREWS AND THE BLACK BUTTON AND THE COVER THAT GOES IN THE FRONT AND HOW TO SET THE MUSIC EQ
Best place to look is on eBay and pick up a DOA unit. There aren’t any parts sold retail. Luckily, any of the e200 series players would suffice to salvage those type of parts from; it doesn’t have to be an ‘R’ (Rhapsody) unit.
The EQ operation and settings are described iin the manual on page 28.
:smiley:
