When a SanDisk portable USB drive stops working, displays errors, or your data abruptly vanishes, you’ll need to recover your files and images. Usually, formatting problems, malware, incorrect ejection, corruption, or accidental deletion cause this. When the SanDisk USB becomes unreadable, users often fear the loss of their memories or important files, but this fear is unfounded.
Initially, attempt to connect the USB drive to a different USB port or computer. Occasionally, however, the port—rather than the drive—is the problem. To fix minor file system errors, you can also use Windows’ built-in tools like CHKDSK and Error Checking. Nevertheless, these manual techniques may fail to retrieve your lost data if the files are erased, corrupted, or the drive requires to be formatted.
A professional data recovery tool can be very useful in this situation. To find corrupted, hidden, or erased files, a recovery tool thoroughly scans your SanDisk USB. Then you can recover documents, videos, images, and more without sacrificing quality by using tools like BLR Data Recovery Software or any other sophisticated recovery software. It allows you to preview your data before restoring it and functions even on SanDisk USB drives that are formatted or RAW.
Without any technical expertise, you have a better chance of safely and swiftly recovering all of your files if you use a reputable recovery tool.
What file system does the TV indicate is being used on this USB drive? (e.g., FAT32 or NTFS).
Can you see this 16GB USB drive within the Windows “Disk Management” interface?
Does this USB drive contain any critical data that absolutely cannot be lost? Or can it be formatted directly?
Step 1: Unlock the Drive Using the TV
Complete Power-Off Method: Insert the USB drive into the TV, shut down the TV normally, and then unplug the TV’s power cord. Wait 2 minutes, then directly remove the USB drive.
TV Safe Eject Method: While on the TV screen where the drive’s files are visible, look for options such as “Disconnect,” “Eject,” or “Safely Remove” within the menu; select one of these options manually before removing the drive.
Step 2: Clean Up “Ghost Drivers” in Windows
Right-click the Windows Start button and select “Device Manager.” Click “View” in the top menu, then check the box for “Show hidden devices.” Expand the “Disk drives” and “Universal Serial Bus controllers” sections. Locate any USB drives or “Unknown devices” that appear semi-transparent (grayed out), right-click them, and select “Uninstall device.” Restart your computer, then insert the USB drive again.
Step 3: Change the Drive Letter (Resolve Path Conflicts).
Sometimes the system detects the hardware but fails to assign it the correct access path.
Insert the USB drive, right-click the Start menu, and select “Disk Management.” Check the list at the bottom to see if your 16GB USB drive appears there (it may be listed as “Unallocated” or lack a drive letter). If it is present, right-click that specific area and select “Change Drive Letter and Paths.” Click “Add” or “Change,” then assign it an unused drive letter (such as X or Z).
Also read this how-to blog: Hard Drive Shows Up in Disk Management But Not My Computer
