SanDisk usb 3.0 Ultra CZ48 128 gb exFat corrupting file on copying to usb
Copying files to 2 new usb drives results in some files being corrupt when accessed. In file properties, Details, all values fields are blank
What OS & app did you use to write the files to the USB drives? Do the files work on the source you copied them from? Are they defragmented? What else was the system doing when the files were being copied? Any AV alerts when copied?
Hi Thanks for your quick response
Attached is info on the problem.
128gb file problem.doc (200 KB)
I suspect it’s a copyright problem. The movie is searching for something hidden on the original cd/dvd.
The detection of file corruption when copying to a SanDisk USB 3.0 Ultra CZ48 128GB with exFAT file system raises concerns. Attention to the video transcribing service is important in such cases. Professional transcription of audio and video is an integral part of creating valuable content. Experienced transcribers possess not only the skills for accurate and fast speech-to-text translation but also the ability to highlight key points and ideas from interviews, lectures, teleconferences, and other audio and video recordings.
Yes, they were example’s but it is happening with any files, photos, word docs. etc.
Regards David.
