Does the Sandisk Sansa base docking station work with the Sansa View? Can you at least use it to charge the View player and download from a computer?
It is possible to use the Sansa View with that dock, (you would need to remove the E200 sleeve adapter) however this will make mounting the player on this dock, less stable as it is not fitting into a sleeve to support it, and could damage the dock, player or both
