hi,
i just bought Sandisk Glide 32GB a few weeks ago and yet this USB had write-protected, i can’t copy data.
do you have any solution for this problem?
There’s only about 43794871368 posts on the forum here about this issue.
Return it. ![]()
WINDOWS MEDIA PLAYER TROLLING FOR MEDIA FILES IN THE BACKGROUND!
First, SERIOUSLY, return it? Sure, hand over all my personal files to get a replacement, derp!
Just had it happen to me, only had media player running and tried to run a backup batch file, got the write error (win7e).
Ejected and retried, then rebooted after the same error, no good.
Then i launched media player after reboot and it reported an “error exiting last session” error - hmmm this is new.
WMP is known to search for media files in the background, even if your have the SYNC features turned off.
I don’t have any add-ins, it was raw WMP that i’m pointing at.
I’m suggesting it tried to update 1 or more media files (artist, album or whatever) and caused the problem.
PLONK, to the old watch drawer!
Dang, the Kingston’s are so ugly, i guess the tiny HP looks good…
http://www.best-flash-drive.com/best-32gb-usb-flash-drive/
HAH, i take it back and will try this one…
Open the old watch drawer and try this fix. http://www.rmprepusb.com/tutorials/54—how-to-fix-write-protected-disks
Exactly same problem here with my 32gb cruiser fit, i have had it just over a year now so i highly doubt they will exchange mine.
I had a simillar problem with a 16gb Transcend usb stick with write protection errors but on their website they have a program that can fix write errors.
Hi The One,
_ Dear member of SanDisk Community, welcome. _
Hmm… See here, and you might have a pleasant surprise.
Link: http://www.sandisk.com/about-sandisk/contact-us/
To find out more on this, see here:
If you want, experimenting with possible solutions, see here:
If you are angry, and think to change brands, before see here:
Enjoy!
Regards, Alfred.
