SanDisk Dashboard not working
I download SanDisk Dashboard offline installer(https://sddashboarddownloads.sandisk.com/wdDashboard/DashboardSetupSA.exe) and double click to run it, but only a splash screen showed up and then disappeared, nothing happened. I run it multipule times in console with following different errors:
未经处理的异常: System.Windows.Markup.XamlParseException: JIT 编译器遇到内部限制。 —> System.InvalidProgramException: JIT 编译器遇到内部限制。
在 System.Windows.Baml2006.WpfSharedBamlSchemaContext.CreateKnownMember(String type, String property)
在 System.Windows.Baml2006.WpfXamlType.FindKnownMember(WpfXamlType wpfXamlType, String name, Boolean isAttachable)
在 System.Windows.Baml2006.WpfXamlType.FindKnownMember(String name, Boolean isAttachable)
在 System.Windows.Baml2006.WpfXamlType.FindMember(String name, Boolean isAttached, Boolean skipReadOnlyCheck)
在 System.Windows.Baml2006.WpfXamlType.LookupMember(String name, Boolean skipReadOnlyCheck)
在 System.Xaml.XamlType.GetMember(String name)
在 System.Windows.Baml2006.Baml2006SchemaContext.GetProperty(Int16 propertyId, XamlType parentType)
在 System.Windows.Baml2006.Baml2006Reader.Process_PropertyIDictionaryStart()
在 System.Windows.Baml2006.Baml2006Reader.Process_OneBamlRecord()
在 System.Windows.Baml2006.Baml2006Reader.Process_BamlRecords()
在 System.Windows.Baml2006.Baml2006Reader.Read()
在 System.Windows.Markup.WpfXamlLoader.TransformNodes(XamlReader xamlReader, XamlObjectWriter xamlWriter, Boolean onlyLoadOneNode, Boolean skipJournaledProperties, Boolean shouldPassLineNumberInfo, IXamlLineInfo xamlLineInfo, IXamlLineInfoConsumer xamlLineInfoConsumer, XamlContextStack`1 stack, IStyleConnector styleConnector)
在 System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
— 内部异常堆栈跟踪的结尾 —
在 System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
在 System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
在 System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
在 DashboardBootstrapper.App.InitializeComponent()
在 DashboardBootstrapper.Core.Program.Main(String args)
未经处理的异常: System.Windows.Markup.XamlParseException: 对类型“DashboardBootstrapper.SplashScreen”的构造函数执行符合指定的绑定约束的调用时引发了异常。 —> System.AccessViolationException: 尝试读取或写入受保护的内存。这通常指示其他内存已损坏。
在 System.Windows.Baml2006.Baml2006SchemaContext.KnownTypes.GetKnownType(Int16 typeId)
在 System.Windows.Baml2006.Baml2006Reader.Process_DefAttributeKeyType()
在 System.Windows.Baml2006.Baml2006Reader.ReadKeys()
在 System.Windows.ResourceDictionary.SetDeferrableContent(DeferrableContent deferrableContent)
在 System.Windows.Baml2006.WpfSharedBamlSchemaContext.<>c.<Create_BamlProperty_ResourceDictionary_DeferrableContent>b__299_0(Object target, Object value)
在 System.Windows.Baml2006.WpfKnownMemberInvoker.SetValue(Object instance, Object value)
在 MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetValue(XamlMember member, Object obj, Object value)
在 MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetValue(Object inst, XamlMember property, Object value)
在 MS.Internal.Xaml.Runtime.PartialTrustTolerantRuntime.SetValue(Object obj, XamlMember property, Object value)
在 System.Xaml.XamlObjectWriter.Logic_ApplyPropertyValue(ObjectWriterContext ctx, XamlMember prop, Object value, Boolean onParent)
在 System.Xaml.XamlObjectWriter.Logic_DoAssignmentToParentProperty(ObjectWriterContext ctx)
在 System.Xaml.XamlObjectWriter.WriteEndMember()
在 System.Xaml.XamlWriter.WriteNode(XamlReader reader)
在 System.Xaml.XamlServices.Transform(XamlReader xamlReader, XamlWriter xamlWriter, Boolean closeWriter)
在 System.Xaml.XamlServices.Transform(XamlReader xamlReader, XamlWriter xamlWriter)
在 System.Windows.SystemResources.ResourceDictionaries.LoadDictionary(Assembly assembly, String assemblyName, String resourceName, Boolean isTraceEnabled, Uri& dictionarySourceUri)
在 System.Windows.SystemResources.ResourceDictionaries.LoadThemedDictionary(Boolean isTraceEnabled)
在 System.Windows.SystemResources.FindDictionaryResource(Object key, Type typeKey, ResourceKey resourceKey, Boolean isTraceEnabled, Boolean allowDeferredResourceReference, Boolean mustReturnDeferredResourceReference, Boolean& canCache)
在 System.Windows.SystemResources.FindResourceInternal(Object key, Boolean allowDeferredResourceReference, Boolean mustReturnDeferredResourceReference)
在 System.Windows.SystemResources.FindThemeStyle(DependencyObjectType key)
在 System.Windows.StyleHelper.GetThemeStyle(FrameworkElement fe, FrameworkContentElement fce)
在 System.Windows.FrameworkElement.UpdateThemeStyleProperty()
在 System.Windows.FrameworkElement.OnInitialized(EventArgs e)
在 System.Windows.FrameworkElement.TryFireInitialized()
在 System.Windows.FrameworkElement.EndInit()
在 MS.Internal.Xaml.Runtime.ClrObjectRuntime.InitializationGuard(XamlType xamlType, Object obj, Boolean begin)
在 MS.Internal.Xaml.Runtime.PartialTrustTolerantRuntime.InitializationGuard(XamlType xamlType, Object obj, Boolean begin)
在 System.Xaml.XamlObjectWriter.Logic_EndInit(ObjectWriterContext ctx)
在 System.Xaml.XamlObjectWriter.WriteEndObject()
在 DashboardBootstrapper.SplashScreen.InitializeComponent()
在 DashboardBootstrapper.SplashScreen..ctor()
— 内部异常堆栈跟踪的结尾 —
在 System.Windows.Application.LoadBamlStreamWithSyncInfo(Stream stream, ParserContext pc)
在 System.Windows.Application.LoadComponent(Uri resourceLocator, Boolean bSkipJournaledProperties)
在 System.Windows.Application.DoStartup()
在 System.Windows.Application.<.ctor>b__1_0(Object unused)
在 System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
在 System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
在 System.Windows.Threading.DispatcherOperation.InvokeImpl()
在 System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
在 MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
在 System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
在 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
在 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
在 MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
在 System.Windows.Threading.DispatcherOperation.Invoke()
在 System.Windows.Threading.Dispatcher.ProcessQueue()
在 System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
在 MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
在 MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
在 System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
在 MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
在 MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
在 System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
在 System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
在 System.Windows.Application.RunDispatcher(Object ignore)
在 System.Windows.Application.RunInternal(Window window)
在 System.Windows.Application.Run(Window window)
未经处理的异常: System.AccessViolationException: 尝试读取或写入受保护的内存。这通常指示其他内存已损坏。
在 System.Windows.Baml2006.WpfSharedBamlSchemaContext.CreateKnownBamlType(Int16 bamlNumber, Boolean isBamlType, Boolean useV3Rules)
在 System.Windows.Baml2006.WpfSharedBamlSchemaContext.GetKnownBamlType(Int16 typeId)
在 System.Windows.Baml2006.Baml2006SchemaContext.TryGetBamlType(Int16 typeId, BamlType& bamlType, XamlType& xamlType)
在 System.Windows.Baml2006.Baml2006SchemaContext.GetXamlType(Int16 typeId)
在 System.Windows.Baml2006.Baml2006Reader.Process_ElementStart()
Segmentation fault
未经处理的异常: System.Windows.Markup.XamlParseException: Get 属性“System.Windows.Controls.Panel.Children”引发了异常。 —> System.TypeInitializationException: “System.Windows.Controls.ItemsControl”的类型初始值设定项引发异常。 —> System.InvalidProgramException: JIT 编译器遇到内部限制。
在 System.Windows.Controls.ItemsControl..cctor()
— 内部异常堆栈跟踪的结尾 —
在 System.Windows.Controls.Panel.VerifyBoundState()
在 System.Windows.Controls.Panel.get_InternalChildren()
在 System.Windows.Baml2006.WpfSharedBamlSchemaContext.<>c.<Create_BamlProperty_Panel_Children>b__217_0(Object target)
在 System.Windows.Baml2006.WpfKnownMemberInvoker.GetValue(Object instance)
在 MS.Internal.Xaml.Runtime.ClrObjectRuntime.GetValue(XamlMember member, Object obj)
在 MS.Internal.Xaml.Runtime.ClrObjectRuntime.GetValue(Object obj, XamlMember property, Boolean failIfWriteOnly)
— 内部异常堆栈跟踪的结尾 —
My env:
Windows 11 64bit
.Net Framework 4.8
sha256sum DashboardSetupSA.exe: ddb18b7adca9b5c79f04edc7e218f1a186df3657c9d6a6eba343f5e7131b866e
Hi @myu
(Get Support for Your SSDs and Flash Products | Sandisk)
(Contact Support | Sandisk)
I am experiencing the same issue, like many many other users what I read online.
I tried everything, AV off(just windows defender), start the program with the command lines, safe mode, nothing works.
It just flashes shortly and that’s it. The most annoying is that I need to update my WD SSD before I can install the latest Windows update, and now I am stuck.
Are there any other options?
After many hours of searching, trying, I finally got a “solution”
  • Downloaded Dashboard version 3.7.2.5. from Majorgeeks
  • Downloaded latest SSD Firmware from Sandisk
  • Rebooted into Safe mode
  • Added prompts -no-sandbox -enable-gpu-support
Then it finally worked, it didn’t worked with all newer versions (v4, v5 etc). This really caused me a lot of headaches, so I hope I can help other people out who experience the same issue (and there are a lot of people judging from the things I see online).
