i´ve bought the Raikko XS Vakuum today and the Sound is realy good for the size.
But there is a problem when i turn the sound louder, then it begins to “tack…tack…tack”.
This problem is only with the Sanza Clip+. With my old MP3 Player, and every other Sound device i tested the probleme is gone and i can hear much louder!!!
The Clip is working fine with all the other boxes i use…
Are you sure the plug is fully inserted in the Clip+? The headphone jack is very tight when the player is new, and it may take a slight amount of force to get it in all the way.
