I have an sandisk 3.2 usb and all sectors are damaged. if i try to create a new volume by using windows it gives me an error. (the usb is a 64 gb one)
How do you know “all sectors” are damaged? Did you run a CHKDSK command on the drive? Did you format the drive and if so did you format it as exFAT?
